P1450 code … maybe purge value? Help needed
Mervjr22
Good evening ,
I noticed after refueling my 2017 Lincoln continental i have trouble getting it started. I usually have to crank it a few times ( only happens after refueling ) check engine light comes on and I get this p1450 code unable to bleed up fuel tank vacuum. On one incident I noticed air pressure or fuel vapors coming out of my nozzle where you insert the fuel pump . I could hear it a feel the air with my hand . Just looking for some advice on what might be the cause. my first guess is a bad purge valve solenoid? ANY HELP IS WELCOME
