My 2024 Nautilus has no wifi nor does it have google services
Hi , I have been using Andriod and works smooth and opens all apps including Andriod Auto and other andriods related apps.
I am using Andriod 13 Carlinkit TBOX MaX 8GB model and works great.
Sorry I haven't used Apple products and not sure.
For GCC this is best replacement but I don't recommend driving with YouTube and other streaming apps as they are also allowed.
So, as expected, I am having no luck pairing the vehicle to the TBOX 😁 the pairing numbers on phone and car screen do not match. The TBOX almost went aerial at one point. Look on YB etc. no luck, hence back on here looking for devine intervention.
Hi VK13,
I have ordered a box though before opening, just wanted to confirm that google maps show on 48” screen?
Thank you, for the guidance 👍🏻
No , unfortunately support for 48 inches screen is not available for carlink it .
Also just to let u know, tbox max that I use has heat sink open and gets hot when carlinkit ambient lighting is enabled.
When the carlinkit ambient lighting is turned off its not that hot.
Hi , I also faced the same issue on my first installation, The TBOX is initially set to connect with apple car play , Car andriod system will connect when TBOX will be in andriod mode.
For this there a small pin hole that u need to keep pressing it changes colour and then restart. Which move it's from car play to andriod auto and then the car should successfully pair to this device.
Then when u press Andriod Auto in the apps screen it will connect.
Once it's paired u can pair your phone to dis device and works with apple or andriod devices.
Waze titles are now working on 48' display on my Nautilus , the feature i was waiting for so long ..
Hopefully available via Apple CarPlay too. Was this update by the dealer or OTA?
Thank you.
Its was on waze application on phone , nothing with the car.
It via waze on mobile connected via Andriod Auto without the carlinkit
I believe this support is only added for carplay by waze 5.4 update on ios
Thank you.
This update was made by waze in version 5.4 for ios and the map is now showing up on 48’ display
However a few improvements could be made for the larger display like showing
- Speed indicator (With speed limit)
- Lane Guidance
- Lane Guidance
Agree with this, hopefully will come with next app update.
Waze has been very unstable, more often than not it does not appear on 48”, freezes or goes to a purple screen.
Have updated app though wonder if vehicle software requires upgrading. Will get the dealer to check.
Waze on 48inch still not stable , i do face freezes also but not purple screen as you have faced.
May be Waze will require few more iterations of upgrade to make it work efficiently.
Letz wait for the some more time for the bugs to be solved.
Any one knows if there is any update on google assistant in gcc ?
Hi Saii97, as previously I was told again this week when car was in for service, that there will be no Google assistant made available here.
It will certainly affect sales as that info slowly becomes more widespread.
Lincoln way app is now available in UAE, but agency says it will be active 1st of July. Did anyone try it and get it to work?
I am waiting for the same , Thanks for the info , is it open for 2024 Nautilus also or only on new purchases ?
As per there info, yes it will work for all lincoln connected, if you have the car now you can try it, they also say once its activated it should update and activate all the google service
i Just tried and still not activated and it shows fleet vehicle , Does it need any update of APIM or something for it to be enabled?
Yea it's the same for me, they said to wait till 1st week of July. It should be fully activated. Lets see
