Hi Slick Fan,
Yes, the rubber plug seems to serve no current purpose, I thought it might be for access to the nuts and bolts that attach the torque converter to the flexplate (flywheel), but not that either. The 1998 and up through 2007 (and probably beyond) use a plate (that appears just like the AOD trans in TABBOOMA's picture) for access to the torque converter bolts from the trans side and a plug on the back of the engine that is removed for access to the nuts from the engine side of the flexplate.
Great that with a 32% oil change (4.5 quarts of a 13.9 quart refill capacity - not dry fill quantity) you noticed a big improvement in trans shifting performance. Sounds like a good plan to flush the trans.
