NunoSimoes
- Jul 8, 2014
Hello all,
I have a 2000 Lincoln Continental and have decided (for no particular reason) to change all the lights to LEDs.
I understand this will trip various sensors so I want some advice regarding load resistors.
I don't know if there are parking light, backup light, or cornering light monitoring systems but I do know there are turn signal and parking lamp monitoring system.
I don't know if I should put individual load resistors at each light or if I should replace the flashing relay with one for LED lights. Also, the number I've seen out there for the load resistor is 50 Watts 6 Ohms, does this sound right?
i would like to install driving lights on it somewhere (and maybe even LED DRL strips), has anyone seen a good install?
Finally, I am also contemplating replacing the standard 9007 headlights with 9007 LED lights (which they claim should just plug right in, $90 for the pair), any problem there?
I don't know if I will get to the interior ones as it seems like it will be a lot of tearing stuff apart.
I would appreciate any advice and suggestions!
Thanks in advance.
Thanks in advance.
