The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
I’ve just been going on looks. I’ll get a measurement and see how much lower it is. There is no noticeable noise and car drives perfectly down the road. Weird!2004 Factory Service manual quantifies "a little" by indicating 0.5" difference in ride height LH vs RH is permissible as spec. Happened across this when looking for other info in the book and thought it was interesting...
So, would that be body mounts breaking down? If so, is that a high dollar endeavor?If you are going to measure, do that at the frame behind the front wheels and in front of the rear wheels. This will tell you IF the vehicle is actually not level or if the vehicle body is not level. Based on your comment of how it drives, one might conclude the suspension* is good, the body or sheet metal not so much.
*Suspension holds up the frame to the driving surface. The body is bolted to the frame.
Measuring from sheet metal or a trim piece is just not accurate at all. (Which may be the issue) Those pieces bolt on and can be adjusted to some degree.
The frame may be level and the body not so much. Which means an adjustment could be made. If you want to go to the expense.
