Keypad unresponsive
Kuskshe
I just purchased a used 2017 MKX from a non Lincoln dealer. I forgot to check the number pad prior to purchase like I had on others we looked at.
The keypad doesn’t do anything. I thought maybe a bad fuse, but according to the fuse map it’s linked to Keypad, Power liftgate module logic power, Hands free liftgate module, SYNC 3 module, and the Embedded Modem which all but the keypad are working fine.
Does the panel light up? Do you know the factory code?
Possibly the Driver Door Module (DDM) connector. The keypad is connected to the DDM and the connector may be corroded causing a bad connection. You would need to remove the driver door trim panel to check the connector. Or check the connection at the DDM.
