Help me with the 2014 lincoln MKT issues
nickool
San Diego
We have purchased a CPO 2014 lincoln-mkt with 39700 miles for less than a month in PA. It is ecoboost model with everything including refridgerator except the rear DVD. We only test drove it for 20 mins and decided to take it for $26890. We just made a trip to NY for around 400 miles. it is a great vehicle but we met several problems with this vehicle.
1. The wind noise in highway is pretty obvious even comparing to our old lincoln LS. I am not sure it is because of the design or just this vehicle. It was a fleet vehicle before with clean title but not serviced with lincoln dealer for the first two years of this car. Today I just noticed some plastic part in the bottom of the body is broken in front of the left and right rear tires, as picture 1 showed. We didn't notice it when we test drive since we only test for a very short time. Is this the reason for the wind noise in highway? Does other mkt owners have the same noise? Should I go to the original dealer to repair the broken plastic part (which is 100 miles away)? We have a close lincoln dealer here too (10 miles away).
2. The car started out from park and feel like the transmission was slipping several round and then suddenly slam into gear (feeling like I was hit from behind) and then would be fine. It happened around one week before too, but not obviously as this time. I knew there are some problems about transmission in a 2010 mkt ecoboost model. Does any other second generation mkt have the same problem? Do I need to request a 'flight recorder' from the dealer to record it since it does not happen everytime? Or should I request the transmission range sensor and pin needed to be replaced witch they are doing now as well as the TSB on the brakes as the 1st generation MKT repair?
3. The plastic end of the safety belt of the second row passenger side is broken and need to be repaired.
4. Because of everything above happened for the last 25 days I owned this car, I decided to run a vehicle heath report and it returns some message URGETN SERVICE REQIURED in the Braking and suspension part ( The icons below may be illuminated in your dash or console or may appear in your message center. The vehicle diagnostics indicate a parameter that is out of normal range or that a component has failed. Systems within your vehicle need prompt service and/or inspection.)
5. Minor thing 1: the health report claimed that mylincoln touch is v3.7 and is the newest version. I knew there is V3.8 already with better siri support for iphone. Is there any link I can download this version since lincoln website won't show me bcz they think it is already the newest version v3.7.
6. Minor thing 2: the leather part of the driver seat outside area is in bad situation and I am not sure what the dealer or I can do with it as shown in figure 3.
7. There are some small dent and scratch in the front and the back door of the car. Can this be covered by dealer and how much the cost will be?
This car is still in bumper to bumper warranty until Oct/2018 and limited comprehensive warranty till Oct/2020. I hope all the repair above will be covered. I am also supervised how many problems this vehicle has since it is certified with Lincoln as CPO cars for 200 points checked. What do they check? The sales man told me they changed the front tires and pads, but not the rear.
I will go to the original dealer where I purchased this car (100 miles away) next Tuesday and any suggestion before that will be very thankful.
For the update, I went to the same webpage and it told me that my version v3.7 is the newest and no more updates.
I just returned my leased 2014 MKT to the dealer at the end of October. It was very quiet on the highways. No wind noises at all. As for the latest MLT version, it is V3.8. I downloaded that version a year ago. As for the Sync account message that you are up to date, mine said that as well even though I knew it was wrong. I find it is always best to go into the software section of the MLT and check to see what it shows there as that will be the most accurate.
There is a TSB for the earlier Explorers on the hard shift/ clunk issue. It also applied to the 2010 & 2011 MKT. http://www.explorerforum.com/xenforo/index.php?threads/2011-explorer-tsbs-ssms.343204/#post-3246033
Cant you go to the closest Lincoln dealer? Lincolns are covered until 50,000 miles.
Got it chekced with the CPO dealer and they can't capture the transmission problem. They also didn't know what the plastic part close to the rear wheels are and since it cost $200, they didn't suggest me repait them. About the brake and suspension code, they told me it belongs to the first owner and I don't need to worry about it. Finally, they said they will order the seat cover for the driver side and replace it, which is around $900 and covered by warranty.
Btw, I still can't find the v3.8 software. Can anyone share the download links for me? Thanks
If you are referring to that small plastic piece mounted to the body and in front of the rear wheels, that is part of the overall aerodynamic features of the vehicle. The 5th generation Explorers have that also.
I believe a V3.8 download was posted in the Explorer forum but I don't know if it is the same as the one for Lincoln as sometimes the software contains certain 'fixes' for a model.
Thanks a lot. Just update the system today and the siri works pretty well now.
"Like" :)
Just purchased a 2014 MKT (36,000 miles), AWD EcoBoost dealer certified. Love the vehicle, but try as I might, can't average more than 14.5 mpg. Lincoln advertises 18mpg, Consumers Report agrees based on their long term test, and a neighbor claims 18 mpg in virtually 100% city driving. Any thoughts as to what might be done to achieve what seems to be the norm in mpg?
My 2014 MKT had about 7500 miles on it when I returned it to the dealer for a 2017 Explorer Platinum. During the time I had it I averaged 17.3 mpg (US) according to Fuelly.com. That was using 87 octane gasoline and about 50/50 city highway driving and using dedicated Winter tires on 18" wheels in Winter.
My 2010 is still going strong but I have the opportunity the I may not be able to pass-up. 2014 MKT with only 33kms (20k miles) for $30k Canadian (US $22.5k). Does it sound to good to be true? Dealer maintained with all service records. Anything I need to look for?? Car was put on the road Dec of 2014 so its just bearly over 2 yrs old. All options except for DVD entertainment.
I have the window sticked and CarProf which is clean. It will be a CPO.
Cliff
The one I mentioned in post 16 was on a 3 year lease but the dealer called saying if I was still interested in a 2017 Explorer they would pay off the remaining 5 lease payments. They did that and then bought it from Lincoln Canada and shipped it to the U.S. because of the $$ value. The MKT wasn't fully loaded. It had the non opening panoramic moonroof and no center console for the 2nd row buckets along with a few missing features. MRSP was just over $58k at the time I leased it. It sounds like $30k is actually a pretty good price. Mine was trouble free for the time I had it. The only minor issue was that with the rain sensing wipers I would get the occasional wipe on a nice sunny day. My 2011 Explorer did that and my 2017 has done it as well. Good luck.
Have anyone had issues with lifegate randomly opening without key fob being used?
