robert574
- Aug 11, 2024
- 2018 MKX 3.7L
Has anyone installed an oem (factory Lincoln) class II trailer hitch on an MKX or a 2019-2022 Nautilus? I'm only talking about the oem hitch and not aftermarket. I can see one on ebay and it looks like the hitch has crimp nuts in its frame so the bolts only go in from the outside with no need for the bolt wires they use to snake the bolts through the car frame.
I'm asking this because I had the oem hitch on my 2018 MKX and I'm purchasing a used 2020 Nautilus and they both use the same hitch. I have a chance to take the hitch off my old car (which is about 45 minutes away) and swap it to the Nautilus later. The dealer has confirmed they are the same but no info on installation.
In that case, it looks like the arms on the hitch would slide inside the car frame and you put the bolts through the car frame and into the hitch maybe.
Anyone?
Anyone?
