I’ve gotten into the habit of switching to conserve mode and disabling the auto start/stop as soon as I start the car. I found that the transmission shifts more smoothly in conserve mode (8 speed trans).
Same here. Also, when using ACC, I like the automatic acceleration profile better.I’ve gotten into the habit of switching to conserve mode and disabling the auto start/stop as soon as I start the car. I found that the transmission shifts more smoothly in conserve mode (8 speed trans).
Setting aside the question of whether or not Lincoln should presume to protect us from ourselves, since any mode other than Normal is displayed on the dashboard it's unlikely that would be missed by the driver for too long. I want to set Conserve mode as my default and will go out on a limb and guess both that Lincoln isn't anti-conservation, and that it won't damage the vehicle.I can see the frustration, but I have to assume that Lincoln has a good reason for this. Maybe to protect ourselves from ourselves. Say you need to use the deep and slippery drive mode but you don't drive for several days after that. You get in and forget you had it there and drive on clean pavement and damage the vehicle. No bueno. Just a theory. This day and age, just another chip or module we all would need to wait for.
The Nav defaults to Normal.
Theory is not good. Ford is not concerned about the climate. Driving in deep or slippery would not hurt the engine or transmission on dry roads.I can see the frustration, but I have to assume that Lincoln has a good reason for this. Maybe to protect ourselves from ourselves. Say you need to use the deep and slippery drive mode but you don't drive for several days after that. You get in and forget you had it there and drive on clean pavement and damage the vehicle. No bueno. Just a theory. This day and age, just another chip or module we all would need to wait for.
I don't normally respond to "Guest" accounts, but here goes.Theory is not good. Ford is not concerned about the climate. Driving in deep or slippery would not hurt the engine or transmission on dry roads.
