Comparison 2024 to 2025 Nautilus Tech Feature Improvements?
While waiting for my window recall I noticed a 2024 Reserve II hybrid in the showroom. It has the blue Lincoln star on front and the blue Lincoln lettering on the doors.
I guess they made a change because my Dec 23 build RII hybrid does not have the blue trim. It is a nice touch.
It looks like you have the Jet Package. I think the Jet option removes the blue colors.
you are correct. I didn't know this.
I think the color priority is set like this…
Gas < Hybrid < Jet Package < Black Label
So only a Premiere/Reserve Hybrid w/o Jet will have blue highlights.
I'm not sure I follow the above. What color highlights do the Jet Package and Black Label get? What if you got a Black Label without the Jet Package?
My understanding is both Jet Package and Black Label have unique coloring (although I think they're similar to each other).
Hybrid turns the lettering blue vs Gas. But Jet Package coloring takes priority regardless if it's a Premiere/Reserve or a Gas/Hybrid. And then the Black Label coloring takes priority regardless if it's a Gas/Hybrid or a Standard/Jet Package.
Right. My hybrid is a BL, but has no blue badging. It is not Jet.
Thanks for that explanation. What color is the Black Label lettering?
Well AFAIK, other than the hybrid blue on black, all the others are white on black, but supposedly the styling is different with each. For the Black Label, the Order Guide says "Black Label Fender Badge", as opposed to the non-Black Label which say "Standard Gas Fender/Door Badge" or "FHEV Fender/Door Badge".
I personally haven't looked that closely to notice.
Thanks again. I'll look closely when I pick mine up on Thursday.
Forgot to mention Jet Package says "Sport Fender Badge". 🤷‍♂️
Best of luck with the new wheels. 👍
Park Assist:
My 2018 Navigator had it. Only used it a very few times but it was a lifesaver those times even though it was somewhat ‘clunky’ since it only handled steering and gave prompts for me to stop/go.
I just last week successfully used the feature on my ‘24 Nautilus … totally automatic … all I had to do after it located the space was hold the button down and it selected and switched forward/reverse controlled accelerator/brake and steered into the space. So much better than previous versions. Though not used often I do want that feature and it’s availability may be a consideration on my future purchases.
