The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
yes and $24 on AmazonAccording to parts.ford.com, the filter is $72.
At that price you can put two in there.Purolator products are on sale now at advance auto. $7 for the compatible cabin filter.
And you literally would need 2 to match the OEM filter thickness.At that price you can put two in there.
pulling the entire glovebox assembly out. Wasn't terribly difficult but there is a lot that you can damage in the process.What is the "hard way"?
Maybe. I saw the other guides and now realize that maybe they were based on the 2023 and older model.@markfm has posted the instructions. Are they the same for all 24 builds?
I can’t drop down the box either. I post the 2 tabs in but there is another mechanism stopping it. Very frustratingDid you remove the entire box or just tried doing it by removing the door to glove box?
Is it really important to replace the cabin air filter? And if so, how often I live in Phoenix Arizona where it’s pretty dusty.
Yes its an awful design. The glide mechanism (thing that makes it open slowly) is on the wrong side and cannot be disconnected. The previous gen had it on the right side and it could be disconnected. This time its on the left and has no method to disconnect it.I can’t drop down the box either. I post the 2 tabs in but there is another mechanism stopping it. Very frustrating
In Central NY I'm pretty consistent in doing annual changes. On our Lexus and Honda they're obviously in need of a change when I pull them (those I change myself, easy).
Mileage based changes also don't necessarily make sense, why we do them annually. The Honda only gets driven a couple K miles per year, but we don't have it garaged, so you get the little odds and ends of stuff (think leaf bits, the little whirly seeds from some trees, pollen); stuff gets in via the air intakes where the hood hinges are, pulled into the air filter when the fan is running.
