Battery being trained radio stays on, lights on window switches stay on 90k miles
Sit in the vehicle and let it idle with all doors closed. Does the door ajar light appear on the dash? If so, then you have door jamb switch issues
Has anyone ever tried a door jamb switch from autozone ?
Have you peeled back the rubber boot in the door jamb to make sure all the wires are intact and not broken? They can get broken over time, I've had that issue in the past (not with my Town Car though).
No door ajar on the dash
Made a video
So I noticed on these parts the starting number is different mines starts with 4WIT and eBay one is 3WIT anyone know if that matters?
Yes it does. If you get a different number it won't work.
The e bay seller I went through sent me the 3WIT
One by accident. Had to send it back. Luckily he had the correct one and sent it with out waiting for the return. I really didn't want to put the door back together just to take apart again.
Also before you put it in write down the keyless code it will be printed on the DDM. You will have to reprogram your keyless entry code. Plus you will have to reprogram your remotes.
