Another Update Hit My 24 Nautilus
Google search finds a 2nd option, does not state that this is new:
  • Method 2: Press the power button five times
    • As an alternative, you can quickly press the audio system's power button five times in a row to initiate the reboot.
Yep. That worked. Thanks.
I just did it successfully using 5 quick press-and-releases. I think it must be done within 7 seconds. So quickly.
I tried more than once so likely do not have the software update.
The update process should be as simple as opening the Software Updates app on the infotainment screen and have a selection to install all available OTA updates so it can be on demand as opposed to using Lincoln's logic.
There is no update history except for last update. This process could be done on phone or web too. If there is some queue it would add you to the "requested" queue.
