bobhamb
- Mar 11, 2023
- Location
- Boston, NY
- 2023 Lincoln Aviator Black Label Touring
There are two small led lights at the hatch ( one on the lower right side & one on the inside of the hatch). They don't make it easy to see what's inside your vehicle. I added a nice very discreet strip light that goes around the whole hatch opening.
The only problem was attaching the power to the right side oem light. The dome light uses a three wire (pos, neg, signal). The signal wire senses the hatch opening/ closing, but the amperage is very low. I tried using various relays (one micro solid state very low voltage relay), but nothing would switch it on/off.
I added a mini normally off momentary switch at the hatch strut and now it works great.
