Hey guys and gals, I have a 97 Continental.
It keeps throwing P0174 and P0171 (bank 1 & 2 Lean). The car has 102k on it.
I have had some idle problems with it, and some power problems as well. trouble idling at all, or having no power what so ever missing like crazy.
I have replaced the plugs and wires with motorcraft parts, replaced the MAF, Coils, and also the O2 sensors. The fuel injectors are fairly new and have less than 30k on them.
Car is my wifes daily driver, she goes through about a 1/2 tank of gas a week. We always buy gas from the same station. I put a can of Sea Foam in the tank @ every oil change.
Since the coils and wires replaced, have not had any idle issue or lack of power. Still throwing lean codes though.
I have an engine vacuum gauge, I have about 18 in Hg vacuum at idle. I have done a smoke test looking for vacuum leaks, I have found none.
I also have an idle "swell" of sorts, it varies from 850~1100 kind of like if you have the ac on, but it does it all the time.
When its not acting odd, it runs like a top, pulls hard, idles smooth and is generally a great car. But when its not running right, sometimes have a hard time getting it to start and idle, and then once i get it to run halfway well, it has no power, doesn't want to accelerate past about 45mph.
