kevin_peter_morris@hotmai
- Nov 5, 2025
- 2025 Nautilus
[] SYNC 5 ISSUE WITH USB DRIVES On a 2025 Lincoln Nautilus []
- After starting the vehicle, I can insert a USB thumb drive & it plays the mp3 songs fine until I shut-off the vehicle.
- I can also insert the USB stick before I start the vehicle & the same thing happens.
- Then, when I restart, one of these 3 things happens:
1 - SYNC says the USB drive is no longer available & I get a message saying it has failed
2 - the drive is still there but SYNC reports there is no media on it
3 - the drive just disappears
- When I check the USB drive on a Windows PC, these 2 things always happen:
1 - Windows always says there are errors. I go thru the scan & repair, sometimes Windows finds errors, sometimes it doesn't
2 - SYNC 5 has copied several new folders onto the USB drive. (Movies, Music, Pictures etc)
- When I re-insert the repaired USB drive back into the Nautilus, the process repeats. This happens every time.
- This occurs on 4 different SanDisk & Samsung USB 256Gig thumb drives.
- These 4 drives always worked fine on my 2017 Lincoln MKX (which I traded in for the 2025 Nautilus)
To troubleshoot:
- I've tried using FAT32, exFat & NTFS formatting. NTFS does not work at all (it did on the 2017 Lincoln)
- I've tried using both the Type A port & the USB-C port with an adapter. (the ones located in the console)
- Why is SYNC always corrupting the USB drives?
- My Lincoln has been getting software/firmware updates.
- I called the 1-800-565-3673 number, talked with Binta, she did some basic troubleshooting, said there are no more SYNC software updates coming for my vehicle & that I cannot submit a "bug report" to her group. My only recourse was to take the vehicle to Ford for diagnostics & servicing. I am sure they CANNOT fix this issue.
- I BELIEVE THIS IS A SYNC SOFTWARE BUG
To troubleshoot:
