2022 navigator mudflap install
TeutonicCarFan
Sr997Gt3
I did a bunch of searching to find mud flaps that fit the navigator.
I started with the weather tech expedition set, which I thought I read that they fit. The fronts work perfectly, and have a good cut out for the running board. The rears do NOT work properly. There must be an indent in the body work on the expedition as they don’t sit flush.
There are not many options readily available for navigator, I took a hunch and hoped the pre refresh would work (mainly because these part sites I don’t believe keep up with this as I assume navigator mud flaps are low volume for them). I found a set for the 2018 navigator. Great the rear sit flush asking the body. The front seat are even shaped to accommodate the deploying running board. They do NOT work. Even though they are cut out they would rub on the board. I saw a video about sliding the board back, went to try that and didn’t want to mess with it.
What ended up working perfectly- weather tech front expedition flaps and partsgeek rear 2018 navigator flaps.
I wanted to post pics but I guess iPhone photos are too large🤷‍♂️
