NOT a Junior Member
50+ year old speakers are toast.
They weren't all that good when new.
Antenna going up and down is a good thing! Mine would not do that. It is fixed now.
A piece of history. These antenna were made by Tenna Corp out of Ohio. Tenna Corp made these for most Ford and GM products in the 1950s into the 1970s. The differences are the top end with bezel and length of tube which dictates how many mast sections. If you wanted, it is possibl to take a power antenna from a GM product and place it on any Ford product with a little modification.
Here is a couple of links about a discussion regarding the Tenna Corp power antenna.
forums.aaca.org
forums.aaca.org
Power antenna
Thanks to the article I wrote about rebuilding power antennas in the ROA magazine last year, I am seeing (rebuilding) more early antenna. I want to thank those that have sent me antenna.The reason for this post is to clarify the differences that I have found. I don't own a Riviera so my reference...
Power antenna
I repair power antenna used on GM vehicles. The '60 -'70's antenna were made by Tenna ....can do those but do not have a supply of replacement mast if your is broken. The 1980 and newer antenna were Delco Slimline (picture with black motor housing) different years/model used different fender moun...
