Scooters Garage
- Nov 28, 2025
- 2007 Lincoln Town Car Designer
Looking for some help. The Light Control Module on 07 Town Car started buzzing intermittently about 6 weeks ago. It’s currently not causing any critical issues but I’m trying to get it taken care of before it does become critical. We’ve owned it for about 8 months. I’ve done the following troubleshooting and repair attempts so far without change. This is initiated by either unlocking remotely or by key.
LCM module number 7W1T-13C788-AA
1. I inspected and cleaned the A and B pillar, front driver and passenger fender body grounds.
2. Inspected splice by A and B pillar.
2. Pulled and replaced all relays in LCM myself.
3. New battery.
4. Disconnected drivers side head lamp connector while buzzing. No change.
5. Replaced the headlight multifunction switch.
6. If I pull either passenger compartment fuse F23 or F26 buzzing stops.
7. Buzzing stops after it warms up for a little while. Sometimes 30 seconds sometimes a couple minutes.
8. Lights and side markers flicker when buzzing as long as headlight switch is in off position. If I turn headlight switch into any other position the buzzing stops. Nothing stays on that after buzzing stops that I’m aware of.
According to the 08 factory manual F23 goes to something called “Logic Batt” F26 goes to “Batt2” in the LCM. Manual doesn’t explain what those are. I have the manual for the 08, not the 07. I’m hoping they are the same. Short story is I ordered the 08 manual thinking I was buying a 08. Surprise when title came in as 07. Anyway.
Any insight into what might be causing this would be helpful. I’m at the point where I’m going to buy back probes to start checking at the plugs. I’m also beginning to suspect that something is telling it to do that.
3. New battery.
