98blacktowncar
- Oct 20, 2025
- 1998 Lincoln Town Car
Hello i have a 98 town car. It has a crank but no start issue. There was also a battery drain issue which i believe i have figured out. I think it was a short in the radio. I pulled both fuses that i could find for the radio and then the car was starting up and running just fine after that. A couple of days ago i went to go start the car again and now it cranks but does not start. Battery is holding charge now. I can hear the fuel pump kicking on when turning the key on. Some things that i have done to the car in the last 3 years i have owned it are
-New starter
-New fuel filter
-New battery
-New pvc valve
-New fuel pump relay
-couple new fuses
-removed alternator and had it tested
-New camshaft position sensor
-New spark plugs
Any help with what the crank no start issue may be would be greatly appriciated. Thanks in advance.
-New starter
-New fuel filter
-New battery
-New pvc valve
-couple new fuses
-New spark plugs
