NavigatorPro
- Mar 19, 2022
- 2018 and 2021 Lincoln Navigator L
Question...What is the tire pressure for 20 inch tires?
Look at the sidewall of the tire…
Basically Im looking for someone with a Navigator that came with 20 inch wheels/tires. They had these in earlier models of the livery edition and the select. If they can check the tire pressure sticker on the drivers door frame near the VIN sticker and let me know.Look at the sidewall of the tire…
Its NOT the vehicle that is having the problem, its the 22 inch tires. These 22 inch tire problems exist on all vehicles that have them and cant be engineered out by the manufacturer. 22 inch tires simply dont last, they dont stand up to things like nails and have a rough ride. The only good thing about them is they have sporty handling for those who desire that kind of handling. So lets say you got the Escalade you will still have the same issues with their 22 inch tires.Oh wow, thats not good for a brand new car with not many miles. Have you thought about just putting newer better tires on it?
I alternate between the stock 22" rims and 20" rims, same Pirelli Scorpion AS Plus 3 tires, so it's an apples-to apples comparison. There is no noticeable difference between the two in terms of handling, and I don't drive like a grandma. The rim size is not the limiting factor when it comes to handling for these trucks. These 22" and 24" rims serve no practical purpose.... The only good thing about them is they have sporty handling for those who desire that kind of handling. ...
There are reports of these particular tires giving harsher ride than some alternatives....
The tires which come on this truck is Michelin Primacy LTX. Michelin is the best maker of tires. They do have the Michelin Defender LTX which will probably make the tires last to around 40k to 50k but they will not entirely solve the issues of the 22 inch tire.
I will disagree.The PSI listed on the sidewall of the tire is the maximum safe tire inflation pressure for the tire.
It is not a recommended tire inflation pressure.
Exceeding the maximum safe tire inflation pressure listed on the sidewall of the tire could result in catastrophic failure of the structure of the tire with severe consequences to safety.
