Questions about Forscan with 2021 Nautilus
proton32176
I can't find a Forscan Spreadsheet for my 2021 Nautilus but I have some questions if anyone can help.
There are a few things about the car that really annoy me so maybe somebody can tell me if Forscan can fix it.
1) The Lincoln Emblem that shines on the ground when you approach the car only works with the mirrors retracted. Can it be changed where it will work when the mirrors are extended?
The mirrors constantly going in and out are going to break, it is only a matter of time. I would rather leave them out but I would like the Lincoln Emblem to show on the ground when they are out instead of only when they are retracted. This may not work since the emblem would probably be sideways with the mirrors extended but I thought i would ask.
2) I have a 2024 Mustang and when you touch the Nav Screen the add phone goes away and the radio replaces it on the right and it STAYS THERE. The Nautilus if I have the Nav screen and the radio to the right the second I touch the climate controls on the center console the Climate Control screen replaces the radio on the right of the screen and I have to take my eyes off the road to get the radio back using the screen arrows.
Can the Nav screen be modified where the Climate Controls don't come up and replace the radio when you change the settings on the center console? I would rather have it where the Nav screen and the radio to the right are the default setting that won't change when I press other buttons.
You would think Lincoln would let you lock in the default screen you want where it would never change unless you wanted it to.
Simple answer: No, and no.
Long answer: 1-It will NOT work since its a hardware issue not a software one. The Lincoln Embrace "Welcome Mat" is electrically disabled while the mirrors are extended. Sure you can mess with the wiring if you really want to, but as you mentioned, even IF you got it working, its not going to look right. 2-That is a bug with SYNC 4. Getting it to reproduce on every vehicle is unlikely. IT may stop doing that after updates fix it. SYNC 4 doesnt have default screens unfortunately. I wish it did, as I prefer the full screen nav with the audio panel to the right at all times.
