DrMitoFit
- May 27, 2025
- Location
- Virginina, USA
- 2021 Corsair and 2011 MKX
I have a 2021 Corsair Standard with metallic vibration noises coming from the right rear when driving over rippled road surfaces or slamming the right rear door shut. It was coming from TWO different sources, but I fixed both. It looks like I may have deleted my first post while editing (or someone else deleted or moved it), so I am reposting.
Right rear bumper marker light has an internal metal reflector that is loose from the factory, replicate sound by pounding it or the right rear bumper. I am NOT talking about the tailgate mounted tail light. Solved by drilling a 1/4" hole in the black interior face of the marker light housing and dripping some caulk onto the interior of the light housing at the upper curved seam where the reflector makes contact with the housing. Worked great!
Amplifier and its bracket vibrate like a tuning fork behind the right rear quarter panel interior trim. Replicated by slamming the rear rear door shut. The amplifier's wiring harness has a rubber mounting grommet that must have fallen out of its slot at the bottom of the bracket. I removed the amplifier with its bracket and inserted a piece of foam between the amplifier and bracket (eliminating the "tuning fork" resonance) and plugged the wiring harness' rubber grommet back into it's slot at the bottom of the bracket (which also helps deaden vibration).
Now my Lincoln Corsair has a quality sound when shutting the doors and drives without the annoying metalic vibrations for the first time ever!
