driller
Senior Member
- Jul 30, 2009
- Location
- Morgantown, WV
- 2024 Navigator L 4x4 Reserve / 8 Passenger / Monochromatic / Equipment Group 201A / HD Towing Package
When you test for voltage on the DG/YW wire, is it still connected to the wiring to the fuel pump?
My thought is to disconnect the fuel pump and test the voltage at the DG/YW wire both at the CJB and inertia switch. I only say this in a generic way as many voltage or resistance checks in typical diagnostic subroutines specify the circuit being tested to be disconnected at a harness connection.
