2024NAVBL
- Dec 17, 2024
- 2024 NAVIGATOR BLACK LABEL
Im not sure what happened to the original thread but going to start a new one. Many were complaining about non L versions having very notable vibration at speeds ranging from 35mph in certain spots to areas upwards of 80MPH+.
Ive been to 2 dealerships over 5 times to address the problem and have had a set of rims changed as well as 2 different complete tire swap outs- first with Pirelli.
In addition to all that ive had outside shops run high speed road force balances to no avail. At one point I made the dealer line up 5 navs for me to drive and 4 of them had the problem- the one that didnt I made them put the tire/wheel pack of that vehicle on mine. It improved the issue but did not remove it and the recent Hankook change improved it largely but the problem is still noticeable at 80MPH and having to trade up Pirelli quality with hankook sucks- the handling is diminished and road noise very noticeable. I only stick to Mich or Pirelli on my cars but will live with this for now.
FINALLY, at least, Lincoln has officially documented the problem with a system reference of "SSM53661" which calls for various tire work/swapping/RF balance/ and alignment. If you have this issue and your dealer says they don't know anything about it or cant figure it out, reference that number as it calls for certain diag approaches and ultimately a change of tires under warranty if they try giving you the run around.
That issue aside, these trucks always have bad manners over local bumps and I think the issue is the lack of amount of sidewall on the 22" factory tires. I am contemplating changing the standard 285/45/22 to 295/45/22 with Micheline. Has anyone else done so or looked into it? It seems the change would provide taller side wall, wider stance, and minimal calc difference affecting the odometer and other systems. Please let me know and ill continue to update any further developments I come across.
