I cannot hear the fuel pump at all.
JIM
Check the inertia switch to see if it is tripped.
And you may not hear the fuel pump if there is enough pressure in the system.
After checking the inertia switch. And a little risky and there is an alternative way to check for fuel pressure at the fuel injectors.
(You have not stated and I am assuming you do not have a pressure gauge)
There is a Schrader valve on the fuel rail. The fuel rail feeds all of the fuel injectors.
Turn the ignition switch to on. (Don't crank the engine)
With a rag to contain spray, use something to depress the Schrader valve. When you do that, fuel should spray out in a good amount.
If fuel sprays out at least you know the pump works to some degree.
If no fuel sprays out there is an issue,
That issue will require a volt meter or test light to diagnose. Plus a wiring diagram. I have not found a fuel system wiring diagram on the net that will allow me to copy and paste. There are a couple of wiring diagrams (or EVTM) listed on eBay.
