The Lincoln website says nothing about some aspects of vehicle maintenance and I am wondering if the Forum can give me better information.
The only things it mentions are the obvious: engine oil, air filters, etc. But what about more obscure areas? Such as PTU, transmission, brake, and differential fluids? Other moving parts lubrications? Lighting?
My dealer just recommended a brake fluid flush at 27.5 K miles. And transmission fluid! $100+ to replace the engine air filter ($12 to $20 part on Amazon and a 10-minute job at home). They must think I was born yesterday.
What do you guys think?
Hi MarkX. What model year? Some fluid maintenance is also time sensitive.
The below information is for more recent model year Lincoln vehicles. So everyone needs to check the Maintenance Schedule for their particular model and model year.
Also, my recommendations below are based on the fact that I keep my vehicles longer than the average. So for those who buy a new vehicle no later than every 4 years or so, you can save money and follow the Maintenance Schedule, if you don’t care what happens after you sell it.
So to start off, for recent model year Lincoln vehicles…There is a Maintenance Schedule located in our Owner Manuals.
That being said, here is some advice/personal opinions:
-You don’t need a brake fluid flush at 27,500 miles. I forget the Lincoln recommendation, so check the Owners Manual Maintenance Schedule and adjust shorter, as you may feel comfortable with.
- The Lincoln Trans fluid flush recommendation is 150,000 miles. I would recommend changing it no later than 50-75,000 miles. Or earlier.
- Lincoln lists the PTU/RDU fluids as “Lifetime”. I would recommend changing them around 50,000 miles or sooner.
- Spark plugs are listed as 100,000 miles. I would recommend changing them no later than 75,000 miles.
- I don’t recall the coolant flush and fill schedule (it is also time sensitive), so check the Maintenance Schedule in the Owners Manual.
- If your vehicle has a changeable fuel filter, it may be a 30,000 mile service item. So check the Maintenance Schedule.
- Yes, engine and cabin air filters are a do-it-yourself item for moderately capable shade tree mechanics. For those who can’t do it themselves, it can be expensive to pay others.
For comparison sake: I just had the transmission fluid and RDU/PTU fluids changed about a month ago on my 2018 MKZ, at just under 30,000 miles.
That’s all for starters. If you’re interested, there are at least several other existing threads discussing this information in more detail.
I’m sure others will jump in with more advice, so let us know how you make out and good luck.
