The Continental doesn't have the moving lights like the MKZ. It does have the corning lights as mentioned above. I know this because I had both an MKZ fully loaded and the Continental at the same time. I was disappointed that they didn't operate like the MKZ. Also the moonroof doesn't work on the Global closing or opening with the Fob.
Hi dmorneau. You do not mention what model year and trim level (nor option packages) your Continental was/is. I am strictly discussing the 2017 Continental Reserve with the Premium LED headlamp option, (which is what the OP is asking about).
So I double checked the 2017 Lincoln Continental Dealer Order Guide (the last word on trim levels, features, options, option packages etc.). and here is what was available:
Concerning the moonroof not being part of the Global Opening feature: You are 100% correct. I incorrectly assumed that feature was available on the Continental, since it was available on the MKZ. My mistake.
Concerning the Premium LED headlamps on the 2017 Continental: When equipped with the Premium LED headlamps, there is a left-right-center sweep system check on startup.
However, the Premium LED headlamps were
not available on the Premier and Select trim levels. They were optional on the 2017 Continental Reserve. And when equipped with the Premium LED headlamps, they did/do have the initial startup check of a left-right-back to center checkup sweep.
If you had/have a 2017 Continental Premier or Select, the LED headlamps were not available and therefore there would be no left/right/center sweep of the headlights.
If you had/have a 2017 Continental Reserve, it either was not equipped with the Luxury Package/Premium LED headlamps, or they were/are not operating correctly.
Hopefully that clears up any confusion.
