Why display ( on dashboard )needs to reset time to time
fishmarco4527
2019 Continental black label
I owned a 2019 Continental black label
My display (Dashboard) Time to time need to reset it. You never know when you come cross this issue
Most of the time when you start the car happening. and stays on x amount of time. Until you restart again.
Hello. When you say reset, what do you mean? I have a problem whereby I set speedometer to km/h, and set temperature to C and distance to Km. Then after a time when I after a few days and some trips come back to the car, it resets back to Miles and Farenheiht.
Is it some thing similar you are experience?
Hello Lincoln owner.
I have a similar problem. But I don't loose my set ups. Just my screen complete blank. You only see odometer needle and Rpm needle on the dashboard. As soon as I go to settings to correction they stay on for days. You never know when this happens by again.
Hello im having a similar problem i set all the dashboard settings to where I want them and then a couple of days it goes back by itself to default ?? Or it changes and I have to put everything again...does anyone know what might be causing this?amd this os on a navigator black label
