ProjectStinkinLincoln
- Jan 22, 2025
- 2001/Towncar Signature
Ok so i bought a 2001 Towncar from facebook and it was fine. After 1 hour of driving every light on the dash cut on exect oil light and battery light . There was vacuum code narrowed it down to the maf and repaired it. Then a few days later the alternator went out and i replaced that but after replacing the all the dash lights cut on again and codes p0155, P0554, p0171, p0161, p0174, appeared. It is also saying low oil pressure and there is a heavy tick, shacking, and water coming from the tail pipe. the body is perfect and there is zero rust so i want to save this car. Do you think i should just put a new motor in or can this one be saved..... if i do need a new 4.6 can i use the 03-11 4.6L with the 01 factory harness and computers or will i need those too.
