tedallen
I had driven to a doctor appointment with no issues and when I attempted to start the Navigator to leave it cranked, but would not start. I think on the first few cranks it might have sputtered slightly, but that could have been residual fuel in the rails.
I checked to make sure the crash detection fuel cutoff switch had not been triggered and it had not. I tested fuse #34 (20A - PCM, IAC solenoid, MAF sensor, Fuel injectors, Fuel pump relay, Fuel pump shut-off switch, Fuel pump motor) and it was good. I disconnected the second connector from top left of the fuse panel in the passenger front kick panel (7 connectors on the top of the face above the fuse panel cover) and checked the bottom left output pin in the panel (where the green wire with yellow tracer from the connector would connect) for voltage when turning the key to the KOEO position and briefly saw close to 12v, but not for the 2-3 seconds I would expect for the fuel pump prime. I then dropped to around 6v and stayed there, even when cranking the engine. That led me to believe it is an issue with the integrated fuel pump relay.
I then ran 12v DC directly from the positive terminal of the battery to the green/yellow wire in the connector that leads to the fuel pump. I assumed I would hear the fuel pump constantly running and when the vehicle was cranked it would start if the fuel pump was working. However, I did not hear it run and the vehicle would not start.
Is there anything else in line to the fuel pump other than the fuel pump shut-off switch that could potentially prevent current from reaching the fuel pump other than a bad connection some where in that path?
I find it hard to believe that both the fuel pump relay and the fuel pump (or something in that path) happened to fail simultaneously. I replaced this fuse panel about 7 years ago for a failed fuel pump relay. I have never replaced the fuel pump in this vehicle, but I did have to drop the tank and replace one in a 1997 Ford Expedition probably 14 years ago.
I appreciate any and all input. We are expecting bad weather her in the Charlotte, NC area starting tomorrow, so I likely won't be able to work on it for the next couple of days. If I can get to Pull-A-Part before bad weather hits tomorrow morning, they have a 2003 and a 2005 Navigator there and maybe at least one of them has the fuse panel.
Thanks,
Ted
Thanks,
Ted
