Lincoln Embrace Dynamic Emblem and Parking Lights - Upgradable for 24/25 Premiere?
DudaSpringHill
Nautilus 2024 Premiere II, Hybrid Equipment Group 102A
I have a 2024 Nautilus Premiere II Hybrid Eq. Group 102A. I absolutely love it, and the various upgrades that were included in the 102A, but if I had one complaint, it's that it doesn't have the full Lincoln Embrace lighting or the lighted emblem that come on the Reserve and Black Label.
Question: Does anyone have technical information on whether the parking light bars (red) and lighted emblem (green) in the picture attached can be upgraded, and what may be entailed (such as additional required components)?
I know there are a couple of after-market options that exist, which would be a far cheaper option, but I'm not interested in these for a variety of reasons.
Any additional information would be greatly appreciated.
If someone with the feature could look at how it is connected, we could find out. The question is if the light bar is an integral part of front grille or fastened. The parts should be available since likely a common part replaced in the crash. The main wiring harness is likely common to all in the front but the specific connections are just unused.
I saw the center emblem is available on parts.ford.com and there appears to be a wiring harness jumper to connect to it. It is hard to tell about the light bar though.
I've done a little research and have confirmed that:
1) The DRL Side Marker Lamp parking light bars are fastened to the front grille and can be replaced, however
2) The DRL Side Marker Lamp parking light bars do require a different headlamp assembly than what is on the Premiere on both sides that includes an additional connector that the light bars connect to. This additional connector enters the headlamp assembly from the bottom of the assembly that appears to be a removable cap for the standard version that does not include the additional connector. It does not appear that the DRL connector can be purchased as a separate component.
3) The headlamp assembly's main connector includes the same eight pins for both headlamp assembly versions, and the wire harness includes eight wires in for the Premiere and the Reserve/Black Label.
Is there a way to have the LINCOLN emblem at the rear glow in reserve or premier models. Example enabling through Forscan or any other way?
No different light bar. Non illuminated.
I saw someone report the rear light assemby was quite expensive (had to be replaced when rear ended). If I recall it was over $2000.
Similarly, does anyone how to make the Lincoln emblem on the front turn blue for a hybrid Reserve model?
I heard it can be done , it's a plug and play thing , you can remove the grill emblem and connect blue emblem, this can be purchased either on Ebay or OEM product.
Hi, I am getting different results when searching for the blue replacement Lincoln Star. Some are ~$65 and some are $250. Any chance you have a part number?
thank you
It seems that since the light bar connects directly to the headlamp assembly, and that both the higher level headlamps and lower level headlamp assemblies have all the same pins. you could likely bypass the headlamp assembly altogether and just tap the light bars directly into the main connector instead.
thank you
If you replace it with a blue emblem would be great to see it in action!
I installed the light bars and emblem on a 2025 nautilus and I do not recommend. Although it was a successful installation, it requires a bit of modifications and breaking clips on the light bars ( but the way they are held in still keep them in place. It's hard to explain. I have a few pictures of the install but I'm not sure how to add them here. Also once installed, I kept receiving a "dynamic front lighting feature currently unavailable" error that would constantly display over and over. Even though the lights were on at all times. The lights came on and stayed on. There were not dynamic but looked cool. I ended up trading it in for a reserve.
