Tom Caldwell
- Jun 13, 2024
- 2017 MKZ
2017 Lincoln MKZ at times won't shift out of park leaving us stranded. Eventually
after turning car off, and after a period of time, it would go back to operating normally. Might be fine for a few days or even a week or two but then would happen again.
Took it to my local Lincoln dealer and they kept it for 3 or 4 days but could not replicate the problem and after testing, running codes etc. didn't find an answer to the issue. Then of course as soon as we took it home it happened again a couple of days later and stranded my wife at the grocery store.
She had our daughter pick her up and went back a few hours later and it shifted fine. Now if she drives it anywhere, she leaves the car running in fear of getting stranded again.
The problem only seems to occur when the car has been turned off and then started and the error message (see below) appears. Again, doesn't happen every time. But if it does shift from park and you drive somewhere and stop and put it into park and leave the engine running it has always shifted into gear again.
The error message that appears is: Shift SYS Fault
