Steve_C
SUPPORTING MEMBER
- Sep 8, 2023
- 2023 Nautilus; 1998 Mk VIII
Here is a Mod I performed recently on my Naut. It is a NOCO charge port attached to the grille. I did this same mod a few years back on my wife's BMW. We rarely use the BMW in the winter, same with the Naut also. This external hookup saves me the trouble of having to unlock & open the doors, open the hood, and connecting the charger to battery, ad nausea. Now, I just plug & play...no fuss! I have a NOCO x2 Charger, so I can hook up both vehicles at once.
I am adding a detachable volt meter to the port so I can quickly check voltage readings when desired. Working on that now.
**DISCLAIMER** this is NOT a “How to Do” mod. I am just showing what I did out of boredom one day. It is at best just a “Show and Tell”.
I am not an engineer so I cannot and do not recommend, nor endorse, or suggest that anyone do this to their vehicle! I did this at my own risk!
Photo 1). Parts (Wire loom wrap not in photo).
I used a NOCO GC002 pigtail (shown in front of the NOCO box). Basically, I just cut this harness in two, spliced in 14g wires to extend the length using the connectors shown to the left of the photo. I used soldering iron to join all, no crimps!
Photo 2). Battery Hookup, I did a bit of re-routing after I snapped this photo to tidy it up a bit more, but this is basically what it looks like.
Photo 3). This was the hardest part! Routing the new harness past the radiator assembly to gain access to the grill was a bit challenging! Took me several tries to come up with a routing that worked! The radiator is sealed all around so no air passes around it. The header panel to radiator cover (not shown in photo) has a lot of molded foam to keep the seal tight as well! This was the routing I came up with so as to not interfere with the foam sealing strips attached to the underside of the header to radiator cover. The new charging loom can be seen at the lower end of the photo, towards the right. The yellow rectangular connector is part of the new charging port harness. To the right of this connector, you can see where it sits in front of the hood bumper stop just behind the header panel. From there it goes back to the battery. This view is with the header to radiator cover off the vehicle.
Photo 4). Now I plug my NOCO here to keep my battery charged during long periods of no vehicle usage.
