jeffcarp
- Oct 17, 2023
- 2024 Lincoln Nautilus (on order)
Overall this looks really good for a first year vehicle.
Thanks for sharing! Top 3 is not bad for a first year redo.Overall this looks really good for a first year vehicle.
Top 3 is good anytime.Thanks for sharing! Top 3 is not bad for a first year redo.
It's hard to understand the reality behind the JD Powers ratings. Their own rating caveat is "Previous year review data used.", meaning it doesn't actually reflect things that came out in 2024.Overall this looks really good for a first year vehicle.
That isn't what that disclaimer means. It means that they are using data from the previous model year in their analysis of the current model. It doesn't mean that their analysis doesn't actually reflect things that came out in 2024.It's hard to understand the reality behind the JD Powers ratings. Their own rating caveat is "Previous year review data used.", meaning it doesn't actually reflect things that came out in 2024.
I do understand that concept, but "surprise" on the injectors (which were an already in use part), and the upcoming front brake change, and... Similarity only gets you so far, if the overall design is changing (the use case) - parts used in an overall different scenario (what the designers are supposed to consider - Is this appropriate? Are we changing stresses that would be expected?)That isn't what that disclaimer means. It means that they are using data from the previous model year in their analysis of the current model. It doesn't mean that their analysis doesn't actually reflect things that came out in 2024.
For example, knowledge of a 2023 transmission can be used in their predictive model for how a 2024 model will perform. It is substantially similar? Is the supply chain the same? Is it used in other products?
JD Power stated methodology has new owner surveys after 90 days of ownership.How do we know that the teething pains aren't reflected in the '24 JD Power Rating? What else would explain a 10% drop in predicted reliability from 88 last year to 80 this year?
