CEB_CLT_Navi_2020
SUPPORTING MEMBER +
- Feb 2, 2023
- 2020 Navi Reserve 4x4
Replaced the battery in my CPO 2020 Navi b/c I kept getting low power / sleep mode warning in the app and we are about to go on an early spring road trip. Also, no idea how old the battery was since I couldn't find any date codes on it. Bought a Costco Interstate AGM for $100 less than FoMoCo with 50 more CCA's than OEM. Easy install.
The question, I have read the ODB2 system needs to have a parameter reset that lets the charging system know a new battery has been installed, I also read that this can be accomplished by pressing the start button with your foot OFF the brake, wait until you see the battery light "on," then flash the brights 5x and then press the brake 5x, the battery light will flash after a few moments and then go out. This procedure resets the ODB2.
Can anyone confirm this is true or do I need to go to my mechanic and get him to reset it with a code reader?
Thanks!
Thanks!
