littleneil
- Feb 23, 2023
The 23 Corsair manual says to enable "auto hold" select features then driver assistance on the synch 4 screen. Can't seem to locate either?
Upper left corner press the Lincoln symbol, then choose Settings, then Driver Assistance. It is somewhere in there. (I'm not in the car right now).The 23 Corsair manual says to enable "auto hold" select features then driver assistance on the synch 4 screen. Can't seem to locate either?
I just got these pics from mine.The 23 Corsair manual says to enable "auto hold" select features then driver assistance on the synch 4 screen. Can't seem to locate either?
Also, once it is engaged, if you put your parking brake on while in park and leave it on, it will continue to engage and release automatically every time you put the car in park and shut off the engine. Nice feature!
Nice job! My '22 Nav does not have that Lincoln logo. What a jip! LolI just got these pics from mine.
hit top left Lincoln logo to get to beginning.
then features on middle right.
then auto hold is the top one. mine is OFF. but toggle it to enable/disable.
Good luck!
I saw that in a youtube video on a Ford F-150. Doesn't appear to be there on my Corsair."Features" should be a tab along the bottom of the infotainment screen.
Did you see my earlier reply with pictures?I saw that in a youtube video on a Ford F-150. Doesn't appear to be there on my Corsair.
No. Will say on your window sticker if equipped.Is it standard on all trims?
Just saw your pix - and just (finally) found the setting. thank you.Did you see my earlier reply with pictures?
Auto hold is standard on all Lincolns now.Is it standard on all trims?
I usually look up order guides but didn't in this case.Auto hold is standard on all Lincolns now.
Things we take for granted:
Back up camera
Reverse sensing
Auto hold
Auto emergency brake assist
Blind spot lights
CarPlay/Android Auto
And lastly simple Bluetooth
These are all standard on every Lincoln. One would be surprised how many comparable vehicles don’t come with most of those unless you pay the bump for whatever ‘package’ has them.
People ask me ‘Does it have CarPlay ?’ which tells me many vehicles they are shopping against us don’t have that either.
Thanks for clarifying my mistake!Auto hold is standard on all Lincolns now.
Back up camera
Reverse sensing
Auto hold
Blind spot lights
Absolutely on the disable auto hold before the car wash. My first attempt was quite embarrassing until I figured out the auto hold was on. From the 2023 owners manual, page 303.My 2021 has physical buttons under the touch screen for this, but it is also SYNC 3.
If you take it to a drive through carwash, make certain you disable the Autohold before you enter the carwash.
When using an automatic car
wash, make sure to switch auto hold
off, or shift to neutral (N) with the brake
pedal applied to ensure auto hold is
not active.
Shift to N with brake pedal applied and not activate auto hold seems like the easy fix.
Wow.My 2021 has physical buttons under the touch screen for this, but it is also SYNC 3.
I assure you there's nothing intuitive about this; I've no idea what auto hold has to do with car washes.Wow.
I thought this would be intuitive but I guess not!![]()
It depends on the type car automatic car wash you use but the one I use is a conveyer type. The kind where you put the car in neutral, take your foot of the brake and rollers pop up and push your car along a track until the wash is completed. Think of that process with your emergency brake engaged. Your car would be held in place, the rollers would continue to try and push your car down the track, and slide under the wheels. And if there is a car behind you there's no telling what might happen. Or the track could sense what was happening to you and automatically shut down.I assure you there's nothing intuitive about this; I've no idea what auto hold has to do with car washes.
