admluvs2fly
- Oct 3, 2020
How do I put the speedometer in the center of the screen.
I have the same problem. I cannot get it in the center of cluster.Thank you all for chiming in. I figured it out. A toggle switch on the left arm.![]()
I have the same problem also... This is so frustrating. I cannot get it in the center. What could be the problem? All I can get is a round circle with a little 0 on the bottom left. This is bad been trying now for days..I have the same problem. I cannot get it in the center of cluster.
I made an appointment for Tuesday. Nothing works. Tach is not selected and the lane keeping on the end of the left blinker arm does not do it either. It came up once and I started it up and have that circle in the middle with the 0 at the bottom of that circle. I have searched for days. Nothing works. I have the reserve model and it did show up last week when I drove it off the lot. Something is wrong..Hi djj and welcome to the Lincoln Forums. Did you read the previous replies? The answer was in Post #3.
If that does not work for you, then you may have a different trim level. In that case you will need to check your Owners Manual for the correct procedure in your model. Or post it here and hope another member can answer.
Can you post a pic of your dash so I can see exactly what it looks like now? I can help you tomorrow but want to make sure what you seek and what I need to help you with.I made an appointment for Tuesday. Nothing works. Tach is not selected and the lane keeping on the end of the left blinker arm does not do it either. It came up once and I started it up and have that circle in the middle with the 0 at the bottom of that circle. I have searched for days. Nothing works. I have the reserve model and it did show up last week when I drove it off the lot. Something is wrong..
Not sure how stopping would change the gauges?Are you talking about the actual digits in the middle of the speedometer or the single circle speedometer display in general?
I just purchased a pre-owned 2020 with the digital dash and I'm confused: I was driving today with the single circle display (tach deselected) but also displayed were the actual digits in the center of that speedometer (in MPH) which we prefer. But...after a stop the digits in the center were gone and I cannot figure out how to get them back despite spending quite a bit of time in the settings.
Any help? What am I missing (that's almost certainly obvious of course)?
If the mph disappeared what it showing now? Can you post a pic?
EDIT: This hastily taken picture proves my point. See below....
"My dealer’s service department claims that the digital speed is not supposed to appear in the center of the speedometer when the HUD is turned on. It is only supposed to appear within the speedometer when the HUD is turned off. However, they said there is a software glitch that causes the digital speed to appear sometimes even with HUD on. Lincoln has not issued a software fix as of 4/21/21."
I guess that's still the case (?).
It’s always there with tach in my very limited experience, but only sometimes without. I turned off the hud and sure enough it was there with speedo only (along with speed limit sign and cruise control displays). Kinda like it without the hud on tbh.EDIT: This hastily taken picture proves my point. See below.
I believe that this is false info. I always have my HUD displayed and I am pretty sure that I have the digital speed in MPH displayed in the middle of the speedo. I also have the tach displayed. I will try to post a picture later, and confirm.
While I don't know for sure, I have had many Hybrids and they have never have a tachometer. I suspect that with the type of CVT (it's not really a CVT) most have, and the racing of the engine when a lot of sudden acceleration is asked for, they don't want to advertise how high the engine is revving. I often wonder why cars these days even have a tach, I have mine displayed because it makes the instrument panel seem more balanced. I never look at it. Doesn't the GT have some kind of power/economy gauge in its place?The owners manual doesn't say. Is there a tachometer available on the GT, I have a 2022 with HUD and can't find one?
Yes, and the screen usually has a lot of blank space that could easily be filled by a tach & more.Doesn't the GT have some kind of power/economy gauge in its place?
I have the 2022 Corsair . 8 inch screenFor anyone to answer that you would need to tell us what model you have and what size instrument cluster. There’s two sizes I believe and the settings are different
