Aviator Full Rear Console
Harleygirl0823
2022 Lincoln Aviator
Is anyone interested in selling me their full rear console? 2020-2023 mode with wood trim.
Thanks
When I was in the market for one, I looked online and salvage yards before finding one on eBay. If you find one, make sure it has the mounting bracket and side trim pieces or else you'll be chasing parts at the Ford dealer. There's also a wire harness that goes from just behind driver seat to the front of the console for the features. Good luck!
Thank you so much!
Any chance you have the part number for the wiring harness you mention with adding the FULL rear console on the Aviator. I managed to install this on my 22 Aviator but can't seem to locate this harness. Any help would be appreciated.
Thanks so much!
Thanks so m
The link below should redirect you to my post with part numbers, etc. To install you might need to remove the left rear seat again to access harness, the plug should have a cap on it. Just plug in and snake it under the carpet to the console.
I installed the full console…question. The carpet is exposed in the corners…I have a mini drink console there before…any thoughts on how to cover?
I appreciate the quick response to this. I called our Lincoln dealer and they ordered the wrong part. THANK YOU SO MUCH!!! I was stuck for a while. I am going to respond to your other post as well. The wire was the last piece. I had been searching for a few weeks in junk part listings as well as Ebay, and other local places. I have a 22 Aviator Reserve with both group201A and luxury packages. It seems the FULL rear console I installed does not fully cover the carpet at the front mounting points. I wonder if the carpet is different with FULL console.
I had the same issue with the carpet. The carpet under rear of console wasn't needed, so I trimmed it some and placed it over bracket tabs on front corners, can't tell unless you're specifically looking for it. Good luck on the part, I don't really see a need to control the sunshade from back seat but the charger ports and ambient lighting is nice.
