Considering CPO Aviator
ChemicalRXN
Hello!
I am researching for a good family hauler and towing vehicle, and Lincoln Aviator seems to fit the bill the best! I am looking at MY2020-2021 CPOs. What are your experiences with your Aviator? I’d like to hear from you!
First, CPO is only way to go!
Second, research every option, you don't want to spend $50K or more and realize you are missing out on something or got the wrong rear console...
There are a good bit of buyback cars out there, CPO avoids that!
If Lincoln is willing to certify a vehicle, it stands to reason that they must have thorough service records on it. Ask to see the service history as a part of your negotiations process.
Hello!
Welcome to the Forum.
I have a 2020 Reserve and I like it so much that I am awaiting the delivery of my 2023 next month. I lease my vehicles and am also a very, very low mileage driver, 6700 miles in 3.5 years. It has been trouble-free during that time.
I would suggest in order to get an idea of member's experiences, that you browse the forum. Many members have already posted about that. Also, remember that many of these experiences can be very subjective. The best thing in the short term would be to test drive the one you are interested in.
I don't know what you expect to tow, but the rating changed from 6700 to 5600 lb. with the 2022 model year without any changes to the vehicle itself.
Good luck and please keep us in the loop.
CPO is an excellent way to get a low mileage good vehicle for much less than the original owner paid for it. They also give a better warranty than a new one ! 6 years from manufacture date or 100k mikes bumper to bumper. I had a CPO MKZ that had troubles and if it wasn’t a CPO I would have been SOL lol
Yep, I traded in a 2021 Jeep Grand Cherokee L Summit I bought new in July of 2021 on this 2020 Lincoln. The warranty actually ends AFTER what my Jeep was due to the CPO perk. (Plus the Grand Touring was a late addition, and its in-service was 7-2020)
DEFINITELY check the In Service Date!
there are many posts to this very topic as hopefully you've availed yourself of.
There are numerous folks who've had significant and/or multiple issues - in most instances I think (don't shoot me everyone) - they are centered towards the hybrid and electrical in nature.
Having said that, we have a 2022 Reserve (gas) that has been w/o issues. We love it in all aspects. Locally I've towed my ~6000# 23' Parker - it does so with aplomb. I'll likely use my Expedition for our annual trip to the Florida Keys this year, but I think this one would do well in any case - I'd just keep the speed down around 65.
I don't think there are any fundamental differences between the older models (at my trim level ) and what we have; others will likely chime in as needed.
Fully aware and as discussed before in other posts I give no credence to said change lacking differences in the vehicles (to which I've found none) between the earlier years and 2023. IMHO they either overrated the earlier years or have underrated 2023.
Also as discussed before, speed matters regarding towing. My local trips to the boat ramp where the speed never exceeds 35 mph are not taxing in any way to this vehicle or even one rated lower. Conversely, at highway speeds one should mind accordingly (and in my case lower the sustained speed).
I was responding to "fundamental changes". I believe that according to what Ford mentioned, they over-rated the 2020-21 models. In any case, whether or not the vehicle can handle it is not a concern since the tow weight is now legally 5600 lb.
The tow rating changed from 6700 lb on the 2020/21 to 5600 lb on the 2022+
Tow rating is 6700 on RWD only models, all the AWD ones are 5600, even 2020.
Yes, correct, if RWD only, the 5600 is the AWD rating.
Just because they can't make the data readable doesn't change that.
I don't think you're interpreting it correctly.
It shows both the RWD and AWD at 6700 with the factory installed Class IV hitch. 5600 with an aftermarket (1) and 6700 with the Class IV (2).
There is no RWD only option shown.
Peter - we all understand what the 'published ratings' are. In our instance of vehicle (at least the 2WD version), however, Ford screwed up. They rated it with 2 different numbers. The 2020 and 2021s do NOT have a higher capacity by 1100 lbs. in real life than the 2023s. Ford messed with people's minds and their own credibility by re-rating the car. It's total nonsense to lower the limit on the 2022s and not publish a formal redaction of the 2020 2021 ratings. I'm highly confident they didn't do that due to lawsuit potential and breech of contract or whatever other legal issues would happen in court.
There is no real single tow capacity limit where 1 lb. under is fine and 1 lb. over is the end of the world. There are many factors to towing - the intent behind the rating is to publish a number w/o constraints (and even then there are some). Any vehicle can tow a 5000# load in their driveway. Much fewer vehicles can safely tow said load at highway speeds. It's all a matter of common sense, brakes on the tow vehicle, tire ratings, vehicle ratings, hitch rating, etc.
I mean this response with all due respect.
That is entirely possible, but I know I read it multiple times somewhere. It may be tied to the overall axle ratio, which may be unique to the RWD as well. I'll keep looking, but most of the time when you see that 6700 mentioned it is also "Max, when properly equipped", but I still think that RWD is one of the "Properly Equipped" tick boxes.
EDIT
Can't find where I read that, but I did find more convincing data for what you're saying. More clearly than the towing guides, and the brochures.
IN THE MANUAL, of all places ;)
This is for a 2020 "normal" Aviator
And FWIW, from MY GT's manual
I agree. I always wondered how can the ratings differ by 1100 lbs without any actual changes to the vehicle. I don't tow anything and when I ordered the 2023 Aviator, I didn't bother with the tow package although it may have had some extras that may have benefited the vehicle.
Thank you for all the replies! (I wasn’t expecting there to be so many replies for my post) And apologies for the late reply - it’s been a crazy busy week at work.
I did notice the de-rating of the towing capacity while reading through the forum. For that reason, I am primarily interested in MY 2020 and 2021 since I can “legally” tow more pounds with the vehicle. I would really like to know the numbers that resulted in the de-rating of the towing capacity…
In terms of CPO vs. buybacks, is there a way I can tell the CPO vehicle is not a buyback vehicle that was repaired and listed for sale as a CPO?
When it comes to looking up the detailed verhicle service history (which I don’t think Carfax provides in detail), is there any other service I can use?
Somewhere and I think it was in the aviator forum someone bought one and it said it was a buy back. Others will chime in and I will see if I can locate it. I think it was bought back for the camera issue
