The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
Usually. I have not done a Continental or full sized F/M.
Thanks for the clarification.
I read that as remove not replace.
This is a stupid design, much like cable door window regulators instead of scissors design which always break cables while scissors design lasts decades. The handle is part of the door panel and it flips a release on the actual door. The Vics and GMs have rods going to the handle which is held to the door by a screw and easily replaced. This design is becoming more common on many cars and the factory fix requires replacing the entire door trim panel. Some aftermarket kits are becoming available but they require cutting and riveting and gluing and the one for the Townies does NOT have the cutouts for the heated seat switches in the supplied panel. This sort of thing must save the factory a dollar per car in labor time or something.
That’s ridiculous, I couldn’t believe they don’t make them for heated and memory seats!This is a stupid design, much like cable door window regulators instead of scissors design which always break cables while scissors design lasts decades. The handle is part of the door panel and it flips a release on the actual door. The Vics and GMs have rods going to the handle which is held to the door by a screw and easily replaced. This design is becoming more common on many cars and the factory fix requires replacing the entire door trim panel. Some aftermarket kits are becoming available but they require cutting and riveting and gluing and the one for the Townies does NOT have the cutouts for the heated seat switches in the supplied panel. This sort of thing must save the factory a dollar per car in labor time or something.
I know this is an older post but likely the reason for many of those changes is not cost it is the government.This is a stupid design, much like cable door window regulators instead of scissors design which always break cables while scissors design lasts decades. The handle is part of the door panel and it flips a release on the actual door. The Vics and GMs have rods going to the handle which is held to the door by a screw and easily replaced. This design is becoming more common on many cars and the factory fix requires replacing the entire door trim panel. Some aftermarket kits are becoming available but they require cutting and riveting and gluing and the one for the Townies does NOT have the cutouts for the heated seat switches in the supplied panel. This sort of thing must save the factory a dollar per car in labor time or something.
Hi. I know it's been a while, but maybe you'll get this. Thanks for giving the screw size. So let's say you use the flick method described in this thread and pull the panel surrounding the interior handle towards the interior of the car and then the door handle goes back into position. Do you still have to remove the entire door panel to put in the screw with the washers washers, or you can just keep the door panel in open the trap door, put the washers on your screw and screw it in. Thanks again!Hey Town Car Cult. So I had the same problem and after looking on line/YouTube/on this forum I fixed the door handle permanently today. Super easy fix took about half an hour and cost $5. What you need is 6mm thread 30 length bolt and some washers. I used a big space washer as the base and then a few smaller ones and then a 6mm lock washer at the end. You have to take the panel off to "reset" the door handle. Once you remove the panel the handle falls right back into place and isn't stuck open. Then just screw in the bolt that goes right into the door and build up the small gap with a few extra washers. I now understand when I saw the YouTube video why the one guy went ahead and did the rest of his doors before the handle was out of position. This avoided having to take the panel off. Yes.....you have to remove the panel in order to get the handle back in its correct position and not stuck open.
6 fasteners in total to remove the panel. 3 at the bottom, the one where the door handle is the 2 pull strap fasteners. Mine came off no problem, no extra tools required. The YouTube video where they epoxy the back and then use the original T30 screw is only if you want to use the little cover to hide the screw. If you were going to do it that way so you could put the cap cover back on what I would do is super glue or epoxy a washer on the back of assembly to give it some stability. If you don't care about what it looks like you don't have to bother with gluing etc as the screw goes right into the door and the washer(s) in the front are what holds everything in place. I will be doing the rest of the doors in the near future on my daily driver Town Car.
Hope this helps. Easy peasy job. In fact I found it easier than the reseal on the air intake gasket. Half hour and you done if you do it with the washer and screw/bolt being exposed. My door handle looked like the one at the top of the thread and would not go back into position. The little jiggle thing video didn't work for me. I don't think the jiggle thing will work if the back of the housing is broken like mine was.
Hey TC2007. From what I remember taking the panel off was only necessary to get the door handle back into position. Once it "resets" you don't need to remove the panel any further. Again, with the rest of the doors, where the handle was fine I just replaced the bolt, did not have to take the panels off. Hope this helps.
