Grab a multimeter and start verifying power then use an alternate radio source hooked up to the speaker(s) to check if they work properlyHow to repair am/fm no audio. CD works perfectly
How does the antenna cable into the radio look? If there is any corrosion I would grab a bit of emery cloth and clean the connectionThanks. I should have given more information. The radio powers up normally, selects am/fm,etc. The audio from cd is normal. A bit of static when on am, nothing when on FM. Antenna is plugged in,
By the way, it is a 2003 Cartier L.
