The car will sit there for an hour or more and still clicks etc.
Hi Stu. In that case, more detail will help.
In your first post, it seemed you had just entered the vehicle... or just turned it off. Now you say the car had been off for an hour? Were you sitting in the car for an entire hour while it was off and it still clicks? Had you just got into the car when the clicks occur?
You see, the details make a big difference. For example: If you just got back into the car after an hour, that means you just approached the vehicle with the keyfob in your pocket. So the vehicle is recognizing the proximity of the keyfob and initiating again.
As a test, try sitting in your vehicle without the keyfob on you. With the keyfob at least 20 or more feet away (i.e. in the house). Then see if you still hear clicks and clacks after a few minutes.
Bottom line, you need provide more details, so that certain variables can be excluded or investigated.
Also, the post of mine you just quoted above was in answer to "felixmendel". My reply to your original post/question was:
"Hi Stu. Due to the keyfob proximity sensors/online modem and other factors some "clicks, clacks, whirls etc." are normal.
Of course, hearing sensitivity can vary and we can not hear what you are hearing, so we can not determine if what you are hearing is normal.
If they are not extremely loud, don't continue interminably, and there does not seem to be any other issues, I wouldn't worry."
My blind Internet guess is that your vehicle is acting normally.
However, it makes no sense for us to guess at all this. That could be why you were asked "Could you be more explicit?".
Get back to us and good luck.
