JADAEASTWOOD
Senior Member
- Jul 15, 2013
Do we drive with over drive on or off? What's preferred?
ive heard that its turned off for driving with speeds under 35-45 and on during interstate speeds, ive always left mine on all the time so
I drive my car with overdrive enabled all the time. The PCM and transmission control module figure out the right gear most all the time. Only times I have used the OD disable is in hilly terrain to avoid the trans hunting for a gear and to provide some engine braking on steep descents. I do not tow a trailer but that can put enough of a load on the car's drivetrain that you may want to disable the overdrive to avoid the trans hunting for a gear.
If I remember correctly, the manual for my Town Car mentioned it would be a good thought to turn it off in stop-n-go traffic as well. But like many others here, I drive with it on all the time.
