Rickward47
SUPPORTING MEMBER +
 - Aug 13, 2025
 - I don't know. That's why I need help.
I'm sure most will think this is bizarre. But I bought a 1992 Lincoln frame with engine, transmission, rear end and tires all intact. The body was cut off under the windshield and all the way around. All the wiring is still intact on the engine. The AC/Heater box has been removed inside and out. All the wires from electric windows, doors, seats, mirrors, fuel tank, gas door, trunk latch and all lights, are lying in the floorboard. I just want to get the engine started for now. I will deal with all the unplugged wires later. A 1948 Dodge convertible body was placed over it to make a rat rod.
I am confused as to which box is the main computer ECU/ECM? I am sending a photo of a box under the dash to the left of the steering column that goes through the firewall under the master cylinder. I am also including a picture of the plug-in outside the firewall. Is that the main computer?
If so, I have a large plug with about 50 pins in it that is plugged into nothing lying on top of the engine. When I look up ECU on google I see boxes that have male pins on the end of them that look like they will plug directly into that empty plug. So, is that the ECU plug and am I missing the ECU to plug into it.
Please review these photos after reading this and tell me if you know what is what! Thank you in advance. Obviously, I'm a moron do please try to educate me.
