Forgot to ask if there's any tutorial video for this job I would greatly appreciate any direction.
Hi RickyMKC. You are very welcome!
Unfortunately…while they probably exist, I can’t recommend any tutorial videos, as I’ve never looked for one for the MKC. Perhaps another member can recommend tutorial videos for the 2016 MKC.
Okay, personal opinion here:
Unless you have a shop quality fluid exchange/flush machine, the usual way for a DIY transmission fluid change nowadays (with essentially sealed units), is the multiple drain (via drain plug if available or suction device), then drive and refill multiple times method. There’s no other simple way to get all the fluid out of the transmission casing, torque converter etc. In my experience, it is a rather inefficient method.
Therefore, my preference and recommendation would be to have the fluid exchanged/flushed by either a Lincoln/Ford Dealership, or an independent shop you trust.
Lincoln/Ford periodically offer coupons for this type of service. So do individual dealerships on their websites. And shop around, since pricing varies by dealership.
And I forgot to mention earlier…while you are at it, change the PTU/RDU fluids (if applicable). While they are considered and listed as “Lifetime” fluids by Lincoln/Ford (and many other auto manufacturers), anyone who cares about their vehicle would not consider that to be correct.
Again, every 50,000-75,000 miles, according to to how careful/proactive you wish to be.
Or 30,000 miles if you routinely tow or drive under other “Severe Duty” types of situations.
