tire replacement
  • Thread starter Thread starter G-868344
  • Start date Start date
G
G-868344
What does Lincoln recommend for all wheel drive vehicles with one tire blow out with 5/32 on the rest of the tires
I don't know what Lincoln says about varied tire wear, but at 5/32nds I stay off the highway in the rain...
If you get any weather of note it sounds like time for a full set, and they're usually cheaper as a set.
Best,
- Jeff
All treads must be the same depth to avoid drivetrain damage. Replace all 4.
Hi G-86. Various manufacturers recommend tread depth must be within 2/32" - 4/32". So in your case, you will be off ~6/32" and will need to replace all 4 tires.
Lincoln also addresses this in the Owners Manual.
+1 ^^^
The wear bars on tires show up at 2/32nds. Most tire stores will not service* tires with 4/32nd or less
*Rotate, balance or flat repair
My previous vehicle, an AWD SUV had 5/32 tread depth which was in spec for them to pass their checklist. 4 mos later the snow came and I was all over the road. That tread level IMHO is unsafe
Hi BC52. Most tire experts (Tire Rack etc.), and tire manufacturer websites I have seen recommend tires have a minimum of 6/32" of tread depth for snow/winter driving (replace at or before 5/32")...and preferably more. And then the tire type makes a big difference, of course.
See here for an example: https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=163
