The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
Is the new Aviator the 2020 that shows in your profile or is that your previous one? I had a 2020 and didn't have any sloshing noises or water in the taillamps.I have a brand new aviator (my second one). Does anyobe else hear what I am assuming is gas sloshing around in the tank when braking to a stop?
Sorry for my quick post few days ago. I read the water doesn't collect in the taillamps. Water gets thru a loose or misaligned taillamp gasket, then drips down the back of the taillamp, which gets the wiring wet, then forms a puddle on the frame, then it leaks into the interior and winds up at the lowest point which is usually the spare tire well.Is the new Aviator the 2020 that shows in your profile or is that your previous one? I had a 2020 and didn't have any sloshing noises or water in the taillamps.
Thank you for the info. There is no collection of water in the spare tire well. I think the aviator just has a lot off noises compared to my other Lincoln’s I’ve owned. And noisy undercarriage over bumps too. Unfortunately.Sorry for my quick post few days ago. I read the water doesn't collect in the taillamps. Water gets thru a loose or misaligned taillamp gasket, then drips down the back of the taillamp, which gets the wiring wet, then forms a puddle on the frame, then it leaks into the interior and winds up at the lowest point which is usually the spare tire well.
My previous 2020 Aviator was quiet and so is my current 2023. Absolutely no noises going over bumps or rough roads.Thank you for the info. There is no collection of water in the spare tire well. I think the aviator just has a lot off noises compared to my other Lincoln’s I’ve owned. And noisy undercarriage over bumps too. Unfortunately.
I have a ‘25 Aviator moving from a Lincoln. The gas sloshing noise is driving me crazy. Did you find a resolution?I have a brand new aviator (my second one). Does anyobe else hear what I am assuming is gas sloshing around in the tank when braking to a stop?
Welcome to the Forum.I have a ‘25 Aviator moving from a Lincoln. The gas sloshing noise is driving me crazy. Did you find a resolution?
No, I guess I’ve accepted it. I still mostly hear in the 3/4 tank range…I have a ‘25 Aviator moving from a Lincoln. The gas sloshing noise is driving me crazy. Did you find a resolution?
I have a 2025 Lincoln aviator and it makes clonking, banging sounds when driving at slow speeds, like moving forward slowly in bumper to bumper traffic or reversing to park. Its quite loud sometimes and disturbing.No, I guess I’ve accepted it. I still mostly hear in the 3/4 tank range…
Welcome to the Forum.I have a 2025 Lincoln aviator and it makes clonking, banging sounds when driving at slow speeds, like moving forward slowly in bumper to bumper traffic or reversing to park. Its quite loud sometimes and disturbing.
I dont know what it could be. The dealership says its the fuel sloshing around but its loud at times and immaculate thay I can feel the impact on top of the center compartment storage and arm restWelcome to the Forum.
I also have a 2025 and previously a 2020 and 2023. I have yet to hear the 'splashing' sound. Are you sure that what you are hearing isn't a shield of some sort? There have been reports of some protective shields causing issues. I believe there is one to protect the fuel tank.
