Rear Windows Tint
jbuch
I need to have the rear window replaced on my 2019 Navigator. I was going to use Safelite and it's asking me whether it's green tint or gray tint privacy. Can someone tell me which one comes standard? Thank you.
HI jbuch. Sorry, I do not know the answer off the top of my head.
However, if you take the part number off the glass (should be visible from the outside, usually in the lower driver-side corner) and Google it, you should be able to find the answer.
Another alternative would be to give the part number to Safelite, and they should be able to determine the type of factory tint off that part number (after all, it is their business).
If still having no luck, try asking the Parts Department staff of your local Lincoln Dealership.
I am sure others will jump in to help, so keep us updated and good luck.
Most 2019 Navigators come with privacy glass, which is usually a darker gray tint. You’ll likely want to choose gray to match the factory look.
