Rear deck speaker
Bigjay64
Austin, Texas
2017 Lincoln Continental Select
Does anyone know if there is a replacement speaker for the rear deck 2017 Lincoln continental select? It’s one speaker but unsuccessful finding original or a replacement.
Hi Bigjay64. I am not sure if there is a replacement available. And replacement availability may be sparse if you have the Revel/Revel Ultima systems.
However, I would recommend you call Crutchfield and ask their experts if there is something available.
They are very good. And if anything may be available, they would very likely be the ones who will know. And if they have something available, you can either purchase from them or take the information and look for a lower price elsewhere.
I’m sure others will jump in to help, so keep us updated and good luck.
Thanks! I absolutely cannot find that speaker anywhere. I understand it is basically a sub speaker. I understand that it is possible to add a sub woofer either in a box or modifying the back panel. I did check the Crutchfield website as they have great inventory. Perhaps I will call for a suggestion on a replacement speaker. Down side, the sound will not be as good as original speaker but it can work. I think going with the sub box in my trunk area will be my choice as it’s cost effective. Thanks again, be well.
Inside the truck, pull the cover down a bit, the speaker is in the center.. weird size, though 8x10.
